roverradio
#1 Posted : Friday, September 1, 2017 6:59:56 PM(UTC)
roverradio
Rank:: Advanced Member
Views messages in topic : 83
I'm almost done with this large project. One last hurdle to get over.
I have the need to do the following via a script:
1) determine current active input (what input is currently selected to the program output)
2) if it is NOT within the range of 20-24, set MultiViewOverlay on an input to a specific number
If anyone is able to whip up a quick script example for that it would really save the day here!
roverradio
#2 Posted : Monday, September 4, 2017 9:12:24 PM(UTC)
roverradio
$100 via PayPal whoever whips this up first! PM me
** someone has completed this **
henry_21pc
#3 Posted : Friday, April 3, 2020 2:14:05 PM(UTC)
henry_21pc
Would you be willing to share the solution to us the mortals? :)
Thanks in advance!
thanks 1 user thanked henry_21pc for this useful post.
studiodelta on 4/9/2021(UTC)
stigaard
#4 Posted : Friday, April 3, 2020 3:27:09 PM(UTC)
stigaard
Denmark
Thanks in advance!
Perhaps you can use something like this.
Code:
Dim doc As New XmlDocument()
doc.LoadXml(API.Xml)
Dim root As XmlNode = doc.DocumentElement
' Select the node active input and fetch input number
Dim node As XmlNode = root.SelectSingleNode("/vmix/active")
Dim inputNumber as Integer = node.InnerXml
' Condition - if the current input number is outside of the range 20-24
If inputNumber < 20 Or inputNumber > 24 Then
   Console.Writeline("MultiView for input 14 updated - on layer1 put input18")
   API.Function("SetMultiViewOverlay",14,"1,18")
Else
   Console.WriteLine("Nothing to change")
   ' API.Function("SetMultiViewOverlay",3,"1,14")
End If
' Console.WriteLine()
thanks 2 users thanked stigaard for this useful post.
henry_21pc on 4/3/2020(UTC), studiodelta on 4/9/2021(UTC)
henry_21pc
#5 Posted : Friday, April 3, 2020 7:29:36 PM(UTC)
henry_21pc
That work perfectly, thanks!
