3rd Party Software and Development
Scripting - determine current active input, if in range do x
Joined: 5/6/2016(UTC) Posts: 83  Was thanked: 5 time(s) in 5 post(s)
I'm almost done with this large project. One last hurdle to get over.
I have the need to do the following via a script:
1) determine current active input (what input is currently selected to the program output) 2) if it is NOT within the range of 20-24, set MultiViewOverlay on an input to a specific number
If anyone is able to whip up a quick script example for that it would really save the day here!
$100 via PayPal whoever whips this up first! PM me
** someone has completed this **
Joined: 5/28/2019(UTC) Posts: 5  Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Would you be willing to share the solution to us the mortals? :)
Thanks in advance!
 1 user thanked henry_21pc for this useful post.
Joined: 5/20/2015(UTC) Views messages in topic : 492   Location: Copenhagen, Denmark Thanks: 422 times Was thanked: 102 time(s) in 79 post(s)
Originally Posted by: henry_21pc  Would you be willing to share the solution to us the mortals? :)
Thanks in advance! Perhaps you can use something like this. Code:Dim doc As New XmlDocument()
doc.LoadXml(API.Xml)
Dim root As XmlNode = doc.DocumentElement
' Select the node active input and fetch input number
Dim node As XmlNode = root.SelectSingleNode("/vmix/active")
Dim inputNumber as Integer = node.InnerXml
' Condition - if the current input number is outside of the range 20-24
If inputNumber < 20 Or inputNumber > 24 Then
Console.Writeline("MultiView for input 14 updated - on layer1 put input18")
API.Function("SetMultiViewOverlay",14,"1,18")
Else
Console.WriteLine("Nothing to change")
' API.Function("SetMultiViewOverlay",3,"1,14")
End If
' Console.WriteLine()
 2 users thanked stigaard for this useful post.
That work perfectly, thanks!
