Using Vmix instead of webcam in Zoom
Thanks: 30 times Was thanked: 1 time(s) in 1 post(s)
I'm hoping to use Vmix as the source of my picture/sound in a Zoom conversation.
I presumed that to do that, I'd need to use the external button in Vmix. In my other app, when I'm looking for a webcam signal, I can't seem to "find" a camera signal though. I've tried all of the options it gives me, but even though I should have a live feed, I just an error message, or no signal.
I'm testing it with Chrome, in the facebook live camera test, and also another online camera tester (webcamtests.com), but while these give me the following options in a dropdown list, none of them work.
Blackmagic WDM capture Blackmagic WDM capture (2) Decklink Video capture (3) Decklink video capture Vmix Video Vmix Video External 2 Vmix Video YV12 Decklink Video Capture (2)
Any ideas of what I need to check?
Joined: 12/27/2012(UTC) Posts: 5,486  Location: Belgium Thanks: 314 times Was thanked: 1019 time(s) in 837 post(s)
Are you saying that when you have external activated you can not find "vMix Video" in your zoom app camera selection (both same computer) ?
correct. (although I'm not using Zoom yet...I'm testing it out on facebook live and the other website I mentioned).
no issue here sorry, Vmix Video (external on) works in zoom and also webcamtest.com and others places That is my webcam into vMix so that one cant be used elsewhere anymore
What are your external output settings ?
Originally Posted by: doggy  no issue here sorry, Vmix Video (external on) works in zoom and also webcamtest.com and others places That is my webcam into vMix so that one cant be used elsewhere anymore
[img=https://imgur.com/gyv7FjZ]vmix settings[/img] Sorry if that doesn't show the image, try this link https://imgur.com/gyv7FjZ
Hmm do you have a separate device for output ??
instead of None and default port ?
Joined: 4/23/2017(UTC) Posts: 1,433  Location: Germany Thanks: 3 times Was thanked: 191 time(s) in 171 post(s)
Maybe a little detour but you could use NDI out of vMix into NDI Virtual Input App. You need to install the NDI tools for that. The virtual input should be seen by other apps just as you would expect the vMix Video.
 1 user thanked mavik for this useful post.
