vMix Call
Vertical blured sides
Hello VMixers, I know there is a feature request about blur ( https://forums.vmix.com/default.aspx?g=posts&t=10341) but do anybody have an idea how to create an similar effect with VMix Version 23? What I need is an effect on an VMix Caller or an other source looks like the attached picture. Thanks a lot for your ideas.  IMG-20200331-WA0007.jpg (167kb) downloaded 4 time(s).
While blurring is impossible one can play with virtual inputs and layer them behind the original with a bit of cropping , repositioning, stretching , color adjustments etc of them to have a somewhat screen filling result be it v23 or older versions. One can go a step further and use some UV-effects
quickie , for edge shadows one might add a Key/Fill to the mix too  cellphone.JPG (113kb) downloaded 3 time(s).
vMix Call
