MrDiSi
#1 Posted : Wednesday, April 1, 2020 3:47:15 PM(UTC)
MrDiSi
Germany
Hello VMixers,
I know there is a feature request about blur (https://forums.vmix.com/default.aspx?g=posts&t=10341) but do anybody have an idea how to create an similar effect with VMix Version 23?
What I need is an effect on an VMix Caller or an other source looks like the attached picture.
Thanks a lot for your ideas.
#2 Posted : Wednesday, April 1, 2020 5:07:22 PM(UTC)
While blurring is impossible one can play with virtual inputs and layer them behind the original with a bit of cropping , repositioning, stretching , color adjustments etc of them to have a somewhat screen filling result be it v23 or older versions.
One can go a step further and use some UV-effects
#3 Posted : Wednesday, April 1, 2020 6:37:09 PM(UTC)
quickie , for edge shadows one might add a Key/Fill to the mix too
