koinonia
#1 Posted : Tuesday, March 31, 2020 4:07:45 AM(UTC)
koinonia
After 23.0.0.49 update, the individual calls are not sending any video and audio individually to my Tricaster using NDI. Outputs 1,2,3 and 4 are ok.
koinonia
#2 Posted : Tuesday, March 31, 2020 4:17:47 AM(UTC)
koinonia
My vmix project (before update) had 5 vmixcalls and I could take each calls from my tricaster using NDI. After update The calls are shown in the NDI list, but no video or audio. Than I created a new project openning 4 vmixcalls and had the same problem. But when I created just one calls it works sending to my Tricaster the call individually. And creating new vmixcalls after that, they worked well, but if you create a project openning vmixcalls and after trying to send individally by NDI we got no video or audio individually, just by outputs.
I hope I could make the problem clear to understand...
#3 Posted : Tuesday, March 31, 2020 12:39:50 PM(UTC)
I can confirm there have been no NDI changes in vMix 23.0.0.49 so this appears to be a configuration issue going by the
note that you were able to get it working by adding new call inputs.
EDIT: I can also confirm NDI works for calls both loading from preset and adding them as new in .49.
koinonia
#4 Posted : Wednesday, April 1, 2020 9:33:22 AM(UTC)
koinonia
Hi Martin,
Thanks for your prompt response!
Yes, you are right. It was a network problem. The vmixcalls and NDI are working very well!
Thanks again for your support!
Daniel Choi
