vMixcalls NDI problem after 23.0.0.49 update
After 23.0.0.49 update, the individual calls are not sending any video and audio individually to my Tricaster using NDI. Outputs 1,2,3 and 4 are ok.
My vmix project (before update) had 5 vmixcalls and I could take each calls from my tricaster using NDI. After update The calls are shown in the NDI list, but no video or audio. Than I created a new project openning 4 vmixcalls and had the same problem. But when I created just one calls it works sending to my Tricaster the call individually. And creating new vmixcalls after that, they worked well, but if you create a project openning vmixcalls and after trying to send individally by NDI we got no video or audio individually, just by outputs.
I hope I could make the problem clear to understand...
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
I can confirm there have been no NDI changes in vMix 23.0.0.49 so this appears to be a configuration issue going by the note that you were able to get it working by adding new call inputs.
EDIT: I can also confirm NDI works for calls both loading from preset and adding them as new in .49.
Martin vMix
Hi Martin,
Thanks for your prompt response!
Yes, you are right. It was a network problem. The vmixcalls and NDI are working very well!
Thanks again for your support!
Daniel Choi
