Hardware Compatibility
How do I bring a Panasonic AW-UE70 PTZ cam into vMix with rtsp?
Hello. I'm not sure if this is the correct category. If it's not, please direct me to the right place. Also, please forgive me if it's a dumb question. I'm not a newb at this subject but I haven't had to ask a question in a forum for a very long time. But now I'm stumped and I need some help!
I'm helping a local church do a permanent install of two Panasonic AW-UE70 PTZ cams in their sanctuary. The install went well, but we are having issues getting vMix to pick them up. rtsp isn't working on UDP or VLC. I don't know if we just haven't found the right URL format or if there is truly no rtsp compatibility here.
Every piece of literature I can find from Panasonic says this model supports rtsp, but I've tried all the URL formats in those sources. We could go NDI, but we are pushing the edge on budget and would prefer not to have to buy the NDI upgrade if we can avoid it.
Any suggestions?
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Can only speak for the HE40 we use, but it is probably similar. Don't know what you have tried. Here is what works for us on RTSP over UDP / RTSP over TCP: rtsp://<cam_ip>:554/mediainput/h264/stream_1 see: https://eww.pass.panason...nt/faq/EN/remcam/33_.pdfAnd in general: - You have to set the "Priority Mode" of the camera to "IP" (not "SD card", and not "USB") - For starters: Turn User authentication off
Originally Posted by: Victory Radio  Hello. I'm not sure if this is the correct category. If it's not, please direct me to the right place. Also, please forgive me if it's a dumb question. I'm not a newb at this subject but I haven't had to ask a question in a forum for a very long time. But now I'm stumped and I need some help!
Any suggestions? Did you check https://eww.pass.panason...or_Web_Control-UE70E.pdf ? Chapter 10
