SRT
Connecting remote graphics operator via SRT
Joined: 3/29/2020(UTC) Posts: 104  Thanks: 20 times Was thanked: 2 time(s) in 2 post(s)
Hi all,
Getting my head around vMix and finding it's quite an amazing bit of software!
I have a project where my contributors, producer and graphics operator are all in different remote locations. I will be switching and mixing the show on my own from my location.
My questing is, can a graphics operator connect to my system via SRT and overlay the graphics themselves using vMix on their system? Does SRT support Alpha channel? Is the video quality good enough to show sharp, 1080p graphics?
Cheers
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
Unfortunately SRT does not support alpha. https://www.vmix.com/help23/index.htm?SRT.htmlYou might be better off having your graphics on your main vMix computer and have your remote graphics operator control them using a 3rd party app like vMix Panel Builder. If you setup vMix on a DDNS server (use something like FreeDNS), you can remotely control your vMix. Your graphics op and producer could then use SRT or vMixcall for monitoring. cheers, Richard
 1 user thanked raugert for this useful post.
Thanks Richard,
So someone can control certain functions of my vMix machine remotely while I am switching the show?
This would be awesome!
The other option I'm thinking is just to have a laptop running the graphics software at my location and feeding it into my vMix PC via NDI. The graphics operator could then remotely control this laptop using Teamviewer or similar.
It would be great if vMix allowed different sections of the switcher (Audio, Graphics,) to be controlled by seperate computers like you can do with Blackmagic ATEM switchers just by connecting vie network connection.
Originally Posted by: Tone13  The other option I'm thinking is just to have a laptop running the graphics software at my location and feeding it into my vMix PC via NDI. The graphics operator could then remotely control this laptop using Teamviewer or similar. That should also work. That way you don't need to setup a DDNS server Originally Posted by: Tone13  It would be great if vMix allowed different sections of the switcher (Audio, Graphics,) to be controlled by seperate computers like you can do with Blackmagic ATEM switchers just by connecting vie network connection. You can do this with the "vMix Panel Builder" app. You can design custom control panels that can be run from separate computers simultaneously, if they are on the same network.
Originally Posted by: raugert  You can do this with the "vMix Panel Builder" app. You can design custom control panels that can be run from separate computers simultaneously, if they are on the same network.
Great! Will look into this. Thanks again.
SRT
