how to display vMix video output on a beamer over local network
Rank:: Advanced Member
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
How can I dispay the vMix video output on a beamer that is on the same local network but not in the same area. So I can't use the external output via the secondary monitor.
vMix has a desktop capture option, I need the opposite way: display vMmix video output on remote desktop.
Joined: 11/21/2013(UTC) Posts: 32 Location: Stockholm
Thanks: 2 times Was thanked: 5 time(s) in 5 post(s)
Couldn't you stream to the beamer?
The beamer has no network. It projects the secondary desktop of a computer.
OK I thought you wrote that it was on the same local network and that you needed to send the screen output to the beamer via a computer. Sorry if i I misunderstood you.
Maybe I was not clear.
I want to send the vMix video output to a computer 50m away on the same local network. And the beamer attached to the extended desktop of that computer has to view the vMix video.
If you ment to stream to that computer, how do I catch that stream and display it on the extended desktop?
Joined: 12/2/2011(UTC) Posts: 77 Location: Europe / The Netherlands
Or just connect the beamer to your local computer (with vMix) via HDMI over UTP? No need for remote computer and since most beamers have multiple inputs...
Is that an option?
I'd use vlc VideoLan to catch the stream and display it on the beamer.
