wwdv
#1 Posted : Wednesday, December 18, 2013 6:22:16 AM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
How can I dispay the vMix video output on a beamer that is on the same local network but not in the same area.
So I can't use the external output via the secondary monitor.
vMix has a desktop capture option, I need the opposite way: display vMmix video output on remote desktop.
tubbis_2
#2 Posted : Wednesday, December 18, 2013 9:43:19 AM(UTC)
tubbis_2
Couldn't you stream to the beamer?
wwdv
#3 Posted : Wednesday, December 18, 2013 11:51:52 AM(UTC)
wwdv
The beamer has no network.
It projects the secondary desktop of a computer.
tubbis_2
#4 Posted : Wednesday, December 18, 2013 4:37:37 PM(UTC)
tubbis_2
OK I thought you wrote that it was on the same local network and that you needed to send the screen output to the beamer via a computer.
Sorry if i I misunderstood you.
wwdv
#5 Posted : Wednesday, December 18, 2013 5:52:57 PM(UTC)
wwdv
Maybe I was not clear.
I want to send the vMix video output to a computer 50m away on the same local network.
And the beamer attached to the extended desktop of that computer has to view the vMix video.
If you ment to stream to that computer, how do I catch that stream and display it on the extended desktop?
ber142
#6 Posted : Wednesday, December 18, 2013 6:54:00 PM(UTC)
ber142
Or just connect the beamer to your local computer (with vMix) via HDMI over UTP? No need for remote computer and since most beamers have multiple inputs...
Is that an option?
tubbis_2
#7 Posted : Wednesday, December 18, 2013 8:00:09 PM(UTC)
tubbis_2
I'd use vlc VideoLan to catch the stream and display it on the beamer.
wwdv
#8 Posted : Thursday, December 19, 2013 6:59:47 PM(UTC)
wwdv
Thanks, I will try that.
