yudhisuisa
#1 Posted : Monday, March 23, 2020 10:58:45 PM(UTC)
yudhisuisa
Indonesia
Hi, i need to record from multiple sources / cameras at the same time by using Multicorder. The problem is, I need to add time stamp / title in each video. If I use single record i can do this, but why Multicorder can't do this? Does anyone have the same issue? Thanks
mavik
#2 Posted : Monday, March 23, 2020 11:06:14 PM(UTC)
mavik
Multicorder is meant as an ISO recorder. Clean Camera feeds for post production.
In 4k and Pro Version you can record 4 outputs. Each output can be set manually to match your needs.
yudhisuisa
#3 Posted : Tuesday, March 24, 2020 4:07:52 PM(UTC)
yudhisuisa
Indonesia
Thanks Mavik for the info.
I try record with 4 outputs as your mention, but the audio wouldn't come out, it showing video only. Maybe you have another tips for this? Thanks
