Add TimeStamp/Title on Multicorder
Hi, i need to record from multiple sources / cameras at the same time by using Multicorder. The problem is, I need to add time stamp / title in each video. If I use single record i can do this, but why Multicorder can't do this? Does anyone have the same issue? Thanks
Multicorder is meant as an ISO recorder. Clean Camera feeds for post production. In 4k and Pro Version you can record 4 outputs. Each output can be set manually to match your needs.
Thanks Mavik for the info. I try record with 4 outputs as your mention, but the audio wouldn't come out, it showing video only. Maybe you have another tips for this? Thanks
