openaspace
#1 Posted : Wednesday, March 18, 2020 3:02:28 AM(UTC)
openaspace
Italy
Hello
I'm trying the latest vmix to stream to some server and with wowza i can't get the
GOP of 60 and 30fps.
Where to set this??
The impossibility to set gops and rtmp frame rate stream with server without encoders create a lot of problems.. with playback stop.
With obs i can reach the correct settings for wowza.
Please help!!!!
Wowza Streaming Cloud - framerate gops.png (8kb) downloaded 1 time(s).
mavik
#2 Posted : Wednesday, March 18, 2020 4:12:46 AM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
The GOP matches if I understand correct. The frame rate depends on your project setting buttom left corner of vMix. You need to set 1080p30 or higher/lower resolutions. You can't specify the frame rate on a per stream basis.
openaspace
#3 Posted : Wednesday, March 18, 2020 9:25:52 PM(UTC)
openaspace
Italy
I'm working with movies at 24fps. Now I'm using OBS with stream at 60 gop and 30fps grabbing the vmix program with ndi plugin on OBS.
I can work with vmix at 30fps playing videos at different frame rate?
