gmm92
#1 Posted : Wednesday, March 11, 2020 8:55:35 PM(UTC)
gmm92
Italy
Greetings everyone, I'm a new user of Vmix and I've been poking aroud the forum in search of answer unsuccessfully.
I am using a clock with this format: {0:mm:ss:f}
However the time showed is basically Vmix's uptime, is there a way to reset the clock to zero and make it start again?
Note: I cannot use the countdown because it does not support a format that allows to show tenths of seconds.
Any help would be greatly welcome!
dmwkr
#2 Posted : Wednesday, March 11, 2020 11:02:50 PM(UTC)
dmwkr
Was thanked: 153 time(s) in 137 post(s)
Tenths of seconds (even hundredths) also work with countdown timers.
Find the code for countdowns here: https://www.vmix.com/kno...-clock-and-timer-options
gmm92
#3 Posted : Wednesday, March 11, 2020 11:30:40 PM(UTC)
gmm92
Italy
I need to count in reverse mode though (count-up, not countdown, there's no indication on how to do that)
Basically I need a timer, that's why I wanted to use the clock with tenths of seconds.
#4 Posted : Wednesday, March 11, 2020 11:42:20 PM(UTC)
Reverse ? yes check reverse!
gmm92
#5 Posted : Thursday, March 12, 2020 12:01:12 AM(UTC)
gmm92
Italy
I am aware of that, I started there and seeing no tenths of seconds format available I tried to use the clock.
#6 Posted : Thursday, March 12, 2020 12:13:31 AM(UTC)
I believe you might be better off with an external stopwatch then
There are many but here is a neat one with lots of options http://www.xnotestopwatch.com/
dmwkr
#7 Posted : Thursday, March 12, 2020 12:20:34 AM(UTC)
dmwkr
UTC could do it, but sync speed will be a problem:
https://forums.vmix.com/...iversal-Title-Controller
Sorry, don't know if there is another way through vMix.
Workaround: Event timer on the production clocks, and create an input from it. You can't style it, though, and it won't stop running.
#8 Posted : Thursday, March 12, 2020 12:42:44 AM(UTC)
Might help to know what the purpose of the clock is
