Greetings everyone, I'm a new user of Vmix and I've been poking aroud the forum in search of answer unsuccessfully.
I am using a clock with this format: {0:mm:ss:f} However the time showed is basically Vmix's uptime, is there a way to reset the clock to zero and make it start again?
Note: I cannot use the countdown because it does not support a format that allows to show tenths of seconds.
Any help would be greatly welcome!
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Originally Posted by: dmwkr  I need to count in reverse mode though (count-up, not countdown, there's no indication on how to do that) Basically I need a timer, that's why I wanted to use the clock with tenths of seconds.
Quote:I need to count in reverse mode though (count-up, not countdown, there's no indication on how to do that) Reverse ? yes check reverse!  reverse.JPG (26kb) downloaded 1 time(s).
Originally Posted by: doggy  Quote:I need to count in reverse mode though (count-up, not countdown, there's no indication on how to do that) Reverse ? yes check reverse!  reverse.JPG (26kb) downloaded 1 time(s). I am aware of that, I started there and seeing no tenths of seconds format available I tried to use the clock.
I believe you might be better off with an external stopwatch then There are many but here is a neat one with lots of options http://www.xnotestopwatch.com/
UTC could do it, but sync speed will be a problem: https://forums.vmix.com/...iversal-Title-ControllerSorry, don't know if there is another way through vMix. Workaround: Event timer on the production clocks, and create an input from it. You can't style it, though, and it won't stop running.
Might help to know what the purpose of the clock is
