Ario
#1 Posted : Monday, March 9, 2020 8:47:31 AM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
The script below creates an event, copies it into the same bank, and sets angles on/off and names them.
It works about 4 times and the 5th time, I get:
"Script '-5_Guest' Error Line 15: The process cannot access the file 'E:\vMix_IRP\replay.xml' because it is being used by another process."
Line 15 is: Function=ReplayCopyLastEvent&Value=1
Kind thanks for any advice.
Function=ReplaySelectEvents2
Sleep 10
Function=ReplayACamera1
Sleep 10
Function=ReplayBCamera1
Sleep 10
Function=ReplayMarkInOutLive&Value=5
Sleep 10
Function=ReplayToggleLastEventCamera2
Sleep 10
Function=ReplayToggleLastEventCamera1
Sleep 10
Function=ReplaySetLastEventTextCamera&Value=2,Score_Guest_1eh_SlamR
Sleep 20
Sleep 20
Sleep 10
Sleep 10
Function=ReplaySetLastEventTextCamera&Value=1,Score_Guest_1eh_Main
Sleep 10
Function=ReplaySetLastEventTextCamera&Value=2,...
(maybe it works better to first copy the event into a different bank, and only then copy it back to the bank it came from?)
dmwkr
#2 Posted : Monday, March 9, 2020 9:13:34 PM(UTC)
dmwkr
I'm not an expert, so just a guess: Does increasing the sleep times before line 15 help?
thanks 1 user thanked dmwkr for this useful post.
Ario on 3/10/2020(UTC)
Ario
#3 Posted : Tuesday, March 10, 2020 1:10:16 AM(UTC)
Ario
I had it at 20 which did not help.
But thanks for the suggestion, I will try it at e.g. 100 and see what happens.
Btw the .xml file is on a fast NVMe drive that only does IRP recording so if it's a write-latency-issue, that should be manageable.
Ario
#4 Posted : Tuesday, March 10, 2020 6:40:50 PM(UTC)
Ario
Well, well, increasing the Sleep to 100 seems to help.
The script produces no errors now:
Sleep 10
Sleep 10
Sleep 10
Sleep 10
Sleep 10
Sleep 10
Sleep 100
Sleep 10
Sleep 10
Sleep 10
Sleep 10
Function=ReplaySetLastEventTextCamera&Value=2,-
