Instant Replay
Script error "replay.xml is being used by another process."
Thanks: 193 times Was thanked: 20 time(s) in 17 post(s)
The script below creates an event, copies it into the same bank, and sets angles on/off and names them.
It works about 4 times and the 5th time, I get: "Script '-5_Guest' Error Line 15: The process cannot access the file 'E:\vMix_IRP\replay.xml' because it is being used by another process." Line 15 is: Function=ReplayCopyLastEvent&Value=1
Kind thanks for any advice.
Function=ReplaySelectEvents2 Sleep 10 Function=ReplayACamera1 Sleep 10 Function=ReplayBCamera1 Sleep 10 Function=ReplayMarkInOutLive&Value=5 Sleep 10 Function=ReplayToggleLastEventCamera2 Sleep 10 Function=ReplayToggleLastEventCamera1 Sleep 10 Function=ReplaySetLastEventTextCamera&Value=2,Score_Guest_1eh_SlamR Sleep 20 Function=ReplayCopyLastEvent&Value=1 Sleep 20 Function=ReplayToggleLastEventCamera1 Sleep 10 Function=ReplayToggleLastEventCamera2 Sleep 10 Function=ReplaySetLastEventTextCamera&Value=1,Score_Guest_1eh_Main Sleep 10 Function=ReplaySetLastEventTextCamera&Value=2,...
(maybe it works better to first copy the event into a different bank, and only then copy it back to the bank it came from?)
Thanks: 64 times Was thanked: 160 time(s) in 144 post(s)
I'm not an expert, so just a guess: Does increasing the sleep times before line 15 help?
 1 user thanked dmwkr for this useful post.
I had it at 20 which did not help. But thanks for the suggestion, I will try it at e.g. 100 and see what happens.
Btw the .xml file is on a fast NVMe drive that only does IRP recording so if it's a write-latency-issue, that should be manageable.
Well, well, increasing the Sleep to 100 seems to help. The script produces no errors now:
Function=ReplaySelectEvents2 Sleep 10 Function=ReplayACamera1 Sleep 10 Function=ReplayBCamera1 Sleep 10 Function=ReplayMarkInOutLive&Value=5 Sleep 10 Function=ReplayToggleLastEventCamera2 Sleep 10 Function=ReplayToggleLastEventCamera1 Sleep 10 Function=ReplaySetLastEventTextCamera&Value=2,Score_Guest_1eh_SlamR Sleep 100 Function=ReplayCopyLastEvent&Value=1 Sleep 10 Function=ReplayToggleLastEventCamera1 Sleep 10 Function=ReplayToggleLastEventCamera2 Sleep 10 Function=ReplaySetLastEventTextCamera&Value=1,Score_Guest_1eh_Main Sleep 10 Function=ReplaySetLastEventTextCamera&Value=2,-
Instant Replay
