NDI
All Inputs as NDI
Is it possible to make all inputs in vMix a NDI Source? I just tested the birddog mini for decoding with vMix and I only could have sent cameras, audio and outputs as NDI sources. It would have been great that I could have sent a slideshow input to a confidence monitor for a presenter.
Joined: 8/5/2017(UTC) Posts: 581  Location: Manitoba Thanks: 121 times Was thanked: 322 time(s) in 184 post(s)
The 4 Outputs in vMIx can be assigned as NDI sources on the network. You can then assign a vMix Input (Camera, Slideshow, Video, etc) to any of those Outputs. Those Outputs will then be available at the BirdDog decoder.
 1 user thanked raugert for this useful post.
I think the number of outputs varies with the version you have. My copy of vMix 4K has 4 explicit NDI outputs. It can also send makes cameras / calls / audio sources available as NDI.
In a project involving two projectors, I send External 1 and External 2 to projectors. Then I program a Streamdeck keypad to control the source to each projector.
Be aware that with full-bandwidth NDI at 1080p60 you can quickly overcome a single gigabit connection to your switch. My vMix host as two NICs which helps a lot.
You have been a member since:: 4/23/2017(UTC) Posts: 1,444  Location: Germany Thanks: 3 times Was thanked: 192 time(s) in 172 post(s)
Yes, it possible. But consider the bandwidth. Settings-Outputs/NDI/SRT Check the additional NDI outputs for Cameras/Calls/Audio inputs. Just enable the NDI switch there and all inputs will be seen via NDI.
 1 user thanked mavik for this useful post.
Thank you all for your replies. I was able to select any input and then turn the NDI on. Great. I am really loving NDI
NDI
All Inputs as NDI
