Instant Replay
Can VMIX recognize this very old LEICTH controller ?
I connect this controller via usb to 9 pin (U232-P9) cable, install drivers and windows recognize it. But VMIX not recognize it when I press a key... My PC: Intel I7 5390K @ 3.6Ghz 16GB RAM WIN 10 VMIX Pro Can anyone help, pls ?  418_G_1510517841089.jpg (17kb) downloaded 0 time(s). oem_00060.jpg (289kb) downloaded 0 time(s).
Joined: 5/18/2015(UTC) Posts: 150 Location: Australia
Thanks: 81 times Was thanked: 109 time(s) in 71 post(s)
This controller is an OEM Custom build from JL Cooper, which uses the Sony 9-pin RS-422 Serial Control Protocols (broadcast), which at this point in time is not compatible with vMix. Leitch, Grass Valley and other broadcast equipment manufacturers have often used the JL Cooper OEM custom control interfaces for their specific application software and hardware. Source: https://jlcooper.com/_php/oem.php
 2 users thanked BETech for this useful post.
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
Shoot me an email. Mart@streaming.eeI'd like to TeamViewer into your PC and see, maybe I could convert the RS232 to something vMix friendly with couple of scripts.
Joined: 12/4/2019(UTC) Posts: 22  Was thanked: 1 time(s) in 1 post(s)
This USB cable is just Serial-to USB converter. When you plug it you get COM-port in Device manager. The only way to make it friends with vMix is to write you own software as i did.
Instant Replay
