Multiple Audio Language Recording
Thanks: 11 times Was thanked: 2 time(s) in 2 post(s)
I will be getting Multiple Audio Tracks (3 in total) in my SDI feed and wanted to record these in the ProRes format for further editing. Does vMix support multiple audio track recording? Any ideas?
Regards, Joel
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
That's not correct in this situation. vMix supports all input sources that have multiple channels of audio within a single "stream" or "track".
1. For SDI inputs, as long as it is Magewell, Blackmagic or AJA, add the camera input and select "EmbeddedAllChannels" as the audio to bring them all in. 2. Next, setup the number of additional buses needed in Settings -> Audio Outputs. 3. Use the Channel Matrix in the Audio Settings of the SDI input to route to the buses as desired. 4. Enable the buses on the SDI input so they are green. 5. When recording to ProRes, select the audio buses to record from the dropdown, such as MAB for 6 channels of audio from Master, Bus A and Bus B.
Originally Posted by: Peter1000  Thanks! It is working.
