NDI
NDI studio monitor switching using script
Joined: 2/25/2020(UTC) Posts: 18  Thanks: 4 times Was thanked: 4 time(s) in 3 post(s)
I use NDI Studio monitor in a live production where it casts vMix outputs. Recently it had been difficult for me to remotely switch sources (there are 4 display and only me running, you can imagine). I found this thread (https://forums.newtek.com/showthread.php/160975-NDI-Tools-4-Studio-Monitor-Switch-Source-via-HTTP-Request?highlight=studio+monitor) where he uses tricaster macro to remotely switch studio monitor with a single shortcut. Does anyone think we can do this using vMix too? or am I just to hopeful?
 2 users thanked zenvideo for this useful post.
Originally Posted by: zenvideo  I looked into this option, but couldn't get it working.
Joined: 4/23/2017(UTC) Posts: 1,484  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
Please look into the Studio Monitor settings - Application - and enable webcontrol. Then you can call that url from any connected device and change settings.
 1 user thanked mavik for this useful post.
Originally Posted by: mavik  Please look into the Studio Monitor settings - Application - and enable webcontrol. Then you can call that url from any connected device and change settings. Thank you for your insight. Currently I am doing this, but opening up a webpage takes quite a bit of my monitor realestate. I as a single operator, I would love to have all options ready for me on vMix.
Originally Posted by: cho123  Originally Posted by: zenvideo  I looked into this option, but couldn't get it working. What was the problem? It works fine when I try it.
Joined: 8/5/2017(UTC) Posts: 582  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
Are all your NDI sources only coming from vMix ? If so, you can just change the NDI output source directly from vMix (cog wheel on the External button) and not have to use the web interface. You could also use a 3rd party app like Panel Builder to create a small switcher panel to switch the NDI Outputs. Not sure if that’s what your looking for ? ... or do you need to control from the devices running the NDI Monitor app ?
I feed the NDI studio monitor app one of the AUX outputs from vMix.
Then I have some buttons on a StreamDeck setup to control those outputs. That way I can give a non-techie helper the ability to changes what's on the Studio Monitor app.
Joined: 1/22/2020(UTC) Posts: 9  Location: California Was thanked: 1 time(s) in 1 post(s)
If you haven't figured this out here is what I was able to get working: I was able to control the settings of NDI Studio Monitor by sending POST/json commands. The computer that will be firing the commands will need CURL installed. Windows 1803 and later has it installed by default. I make a .bat file with the CURL command which can then be added to a button on the StreamDeck. Here is a command that does the following:
- Sends command to 192.168.20.206
- Switches input to computer/input: KI10 (Test Pattern)
- Sets display to full screen on a single monitor system
- Sets to always on top
Code:curl "http://192.168.20.206/v1/configuration" -X POST -d "{\"version\":1,\"NDI_source\":\"KI10 (Test Pattern)\",\"window\":{\"display_device\":\"Full Screen\",\"always_on_top\":true}}" -H "Content-Type: application/json"
The easiest way to get the specific setting you need is to setup Studio Monitor the way you want it then from a browser send: http://xxx.xxx.xxx.xxx/v1/configuration This will return all the current settings. You must have the version:1 and you must reformat to match what CURL needs, but you can use this to see how settings are referenced. I use Advanced REST Client app to help format the commands. Here is also some into for using CURL. It references a format changed that needs to happen from Advanced REST Client to CURL on Windows. I hope this helps!
 1 user thanked MattyG for this useful post.
good morning, thanks for the guide. I wanted to ask you what command should I use instead to send a full screen to the second monitor? thank you Originally Posted by: MattyG  If you haven't figured this out here is what I was able to get working: I was able to control the settings of NDI Studio Monitor by sending POST/json commands. The computer that will be firing the commands will need CURL installed. Windows 1803 and later has it installed by default. I make a .bat file with the CURL command which can then be added to a button on the StreamDeck. Here is a command that does the following:
NDI
