cho123
#1 Posted : Friday, February 28, 2020 6:06:31 AM(UTC)
cho123
I have been using vMix with NDI for 8 month now and I recently started to experience weird shutdown. After an hour long production with vMix, I usually won't able to close the vMix unless I use either use task manager or window's app crash. This happens all the time, even when you have just 1 ndi camera input. I do excessively use NDI for my production case(and probably over my system spec), but I was wondering if anyone else had the same issue.
vMix 4k: 23.0.0.39 x64
with NUC8
#2 Posted : Friday, February 28, 2020 1:04:15 PM(UTC)
What sort of NDI sources are you using?
There is some known issues caused by faulty NDI encoders, so I would suggest dropping us an email so we can confirm if this is the case for you or not.
https://www.vmix.com/contact-us.aspx
