Joined: 2/25/2020(UTC) Posts: 18  Thanks: 4 times Was thanked: 4 time(s) in 3 post(s)
I have been using vMix with NDI for 8 month now and I recently started to experience weird shutdown. After an hour long production with vMix, I usually won't able to close the vMix unless I use either use task manager or window's app crash. This happens all the time, even when you have just 1 ndi camera input. I do excessively use NDI for my production case(and probably over my system spec), but I was wondering if anyone else had the same issue.
vMix 4k: 23.0.0.39 x64 with NUC8
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
What sort of NDI sources are you using? There is some known issues caused by faulty NDI encoders, so I would suggest dropping us an email so we can confirm if this is the case for you or not. https://www.vmix.com/contact-us.aspxRegards, Martin vMix
