Capture Resolution is not supported
Joined: 9/29/2017(UTC) Posts: 16 Location: Surrey, BC
Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
Hello - I have 2 logitech webcams installed.
1. Logitech HD PRO Webcam 920 Input: Default Resolution: 1920x1080 Frame Rate NTSC 29.97p
I get this error AddNewInput.The following are supported:
640x480 NTSC 30p MJPG 160x90 NTSC 30p MJPG 160x120 NTSC 30p MJPG 176x144 NTSC 30p MJPG 320x180 NTSC 30p MJPG 320x240 NTSC 30p MJPG 352x288 NTSC 30p MJPG 432x240 NTSC 30p MJPG 640x360 NTSC 30p MJPG 640x480 NTSC 30p RGB 160x90 NTSC 30p RGB 160x120 NTSC 30p RGB 176x144 NTSC 30p RGB 320x180 NTSC 30p RGB 320x240 NTSC 30p RGB 352x288 NTSC 30p RGB 432x240 NTSC 30p RGB 640x360 NTSC 30p RGB 640x480 NTSC 30p I420 160x90 NTSC 30p I420 160x120 NTSC 30p I420 176x144 NTSC 30p I420 320x180 NTSC 30p I420 320x240 NTSC 30p I420 352x288 NTSC 30p I420 432x240 NTSC 30p I420 640x360 NTSC 30p I420
Unspecified error
2. Logitech HD Webcam C615 Input: Default Resolution 1280x720 Frame Rate: NTSC 29.97p
640x480 NTSC 30p MJPG 160x120 NTSC 30p MJPG 176x144 NTSC 30p MJPG 320x240 NTSC 30p MJPG 432x240 NTSC 30p MJPG 352x288 NTSC 30p MJPG 640x360 NTSC 30p MJPG 640x480 NTSC 30p RGB 160x120 NTSC 30p RGB 176x144 NTSC 30p RGB 320x240 NTSC 30p RGB 432x240 NTSC 30p RGB 352x288 NTSC 30p RGB 640x360 NTSC 30p RGB 640x480 NTSC 30p I420 160x120 NTSC 30p I420 176x144 NTSC 30p I420 320x240 NTSC 30p I420 432x240 NTSC 30p I420 352x288 NTSC 30p I420 640x360 NTSC 30p I420
Unspecified error
Both were working 3 days ago. Please help.
So I did all those changes as recommended supported error. The C615 is working. I did a change for C920 but it takes so long to come up.
is there a vMix for 32 bit?
The C920 finally came up but with an error "A device attached to the system is not functioning"
I think I have fixed it. We will see how long this will last. I unconnect and reconnect into another port.
stampersplus wrote:is there a vMix for 32 bit? Go to Start / All Programs / vMix, and you'll see two icons to start vMix, vMix(64) and vMix. The 32bit version starts with the "vMix" icon. I sounds as if you had both webcams on the same USB 3.0 buss. However, switching to a different port may have fixed the problem.
SportsNetUSA.net wrote:stampersplus wrote:is there a vMix for 32 bit? Go to Start / All Programs / vMix, and you'll see two icons to start vMix, vMix(64) and vMix. The 32bit version starts with the "vMix" icon. I sounds as if you had both webcams on the same USB 3.0 buss. However, switching to a different port may have fixed the problem. I only have the trial version.
Joined: 2/23/2020(UTC) Posts: 3   Location: Chattanooga, TN
I realize this was an old post....yet..... How were you able to resolve this issue? I have the 60-day (full function, 1920x1080) software, and, I can not connect the Logitech C920 as an input. Tried many steps and get different errors. Any insights would be appreciated! Thank you!
The C920 should be detected by windows automatically. Just plug it into a free USB port. In vMix press add input at the bottom left. Go to the camera section. Select the C920 from the drop down. Enjoy.
Originally Posted by: mavik  The C920 should be detected by windows automatically. Just plug it into a free USB port. In vMix press add input at the bottom left. Go to the camera section. Select the C920 from the drop down. Enjoy. Thank you for such a prompt response, much appreciated! I was able to get it working using the 1920x1080 H264 Low Latency with a 30p frame rate. In addition, had to disable the mic on the camera so I could use the Yeti mic/headset. Not sure why the C920 and Elagato sound capture still show up in the Audio Mixer section since these were not added. I had only added an input for the Yeti. How does "toggle automatic audio mixing" work? Again, thank you!
Originally Posted by: PRKid  How does "toggle automatic audio mixing" work? Again, thank you! Figured this part out, though hard to interpret with the 2 arrows pointing in different directions and on/off toggle.
