ukcpw
#1 Posted : Wednesday, February 19, 2020 1:40:24 AM(UTC)
ukcpw
Hi all,
I've just had a strange reaction from vMix : pressing a shortcut to play some music track on a Stream Deck, my fullscreen multiview changed !!! There is no other hidden shortcut or cloned stuff, I didn't even know that you could change the mutiview aspect with a shortcut. Fact is I need to go back to the settings each time to set it back to how it was...
Here is a video to show you... any help ?
VMIX BUG VIDEO
ukcpw
#2 Posted : Wednesday, February 19, 2020 3:26:24 AM(UTC)
ukcpw
EDIT : I just discovered after running several tests, that it has nothing to do with the shortcuts, but with the master audio level... when the audio level peaks at 0 (which could happen often...) the multiview display changes !
#3 Posted : Wednesday, February 19, 2020 12:35:26 PM(UTC)
Was thanked: 4644 time(s) in 1605 post(s)
That is quite strange, best to send a support report from Settings -> About in vMix and drop us an email.
Many years ago (as in around vMix 12!) there was a multiview meter rendering bug, where out of spec audio signals (> 0db) would cause the multiview output to fail.
This would switch back to the old multiview as a fallback, but as a test here I just add audio sources with various peaking levels and could not replicate it
so something strange about that particular setup is triggering it somehow.
ukcpw
#4 Posted : Wednesday, February 19, 2020 6:11:17 PM(UTC)
ukcpw
Thanks Martin, will do today.
FYI, I tried different outputs on my graphic cards and different presets on vMix, and of course restarting comp and vMix, the problem persists though. Updated to .39 last week.
Regards
