Hello, I want to know if it's possible to customize the Web controller interface with, for example, html files ? If not, how is it possible to have status information of vMix with API? Indeed, I can send function to the API with requests like http://127.0.0.1:8088/api/?Function=Fade&Duration=1000 but I dont know how to have status of vMix information? Thank you in advance. Cordially.
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
when you link to http://127.0.0.1:8088/api/ in a browser you will get a lot of info in the resulting xml being displaye to get some info or status on things you can check elements of the that xml file some examples on how to do it you can find HERE
