jurick
#1 Posted : Wednesday, February 12, 2020 2:21:08 AM(UTC)
jurick
I want to know if it's possible to customize the Web controller interface with, for example, html files ?
If not, how is it possible to have status information of vMix with API? Indeed, I can send function to the API with requests like http://127.0.0.1:8088/api/?Function=Fade&Duration=1000 but I dont know how to have status of vMix information?
Thank you in advance. Cordially.
#2 Posted : Wednesday, February 12, 2020 3:42:57 AM(UTC)
when you link to http://127.0.0.1:8088/api/ in a browser you will get a lot of info in the resulting xml being displaye
to get some info or status on things you can check elements of the that xml file
some examples on how to do it you can find HERE
