xemles
#1 Posted : Monday, February 10, 2020 10:11:32 AM(UTC)
xemles
France, Metropolitan
I'm trying to setup an audio delay in negative, since the video delay isn't really smooth, the problem is that when I do this: UserPostedImage
It doesn't change anything for the Recording, it works when in positive but not in negative
mjgraves
#2 Posted : Tuesday, February 11, 2020 12:49:53 AM(UTC)
mjgraves
Negative delay is not possible. You can't get a signal to arrive faster than it actually arrives. It would require time travel.
You must delay all other things to be in time with the latest arriving signal.
MartLeib
#3 Posted : Tuesday, February 11, 2020 4:12:41 AM(UTC)
MartLeib
Estonia
vMix adds artificial delay to Audio inputs to combat video capture delay so video and audio would be in sync. You can use negative delay on the Audio inputs. It is not per say negative so it would arrive before the signal arrives (requires time travel) but removing that artificial delay is possible using the slider OP has captured, hence the negative delay.
thanks 1 user thanked MartLeib for this useful post.
danhoff on 8/5/2020(UTC)
