Trigger stinger 1 second before the end of the clip
Hi! Is it possible to trigger stinger (or video clip) BEFORE end of video? Something about not OnCompletion, but BeforeCompletion with xxx milliseconds? Thank you!
Not standard way i know of but you could read the position & duration status from the API xml of the used input and calculate the remaining time you want to use and instruct the stinger function accordingly (script)
@ dim_111
You have a couple of options:
a) You could adjust the "Mark Out" point of the video clip and use the "OnCompletion" Trigger. b) If you know the length of the video, you could set up a timer that is just shy of that and use the "OnCountdownCompleted" Trigger.
Joined: 7/8/2016(UTC) Posts: 53   Location: Ukraine Thanks: 13 times Was thanked: 5 time(s) in 3 post(s)
Ice option "a" - not good. I think, because I have same problem, it's because stinger with alpha chanel, so it must start 1 second to the end, else it will be freeze picture with a stinger.
@ tkachk.alex
Then option "b" should work well if set-up properly. That is, Trigger the countdown to start when the video transitions in and Trigger the Stinger to play on countdown completion. (I might suggest giving it more than a second depending on your Stinger, but a little trial and error tweaking to get it right and it should work like a charm)
