dim_111
#1 Posted : Wednesday, February 5, 2020 4:21:53 AM(UTC)
dim_111
Hi!
Is it possible to trigger stinger (or video clip) BEFORE end of video? Something about not OnCompletion, but BeforeCompletion with xxx milliseconds?
Thank you!
#2 Posted : Wednesday, February 5, 2020 4:41:37 AM(UTC)
Not standard way i know of but you could read the position & duration status from the API xml of the used input and calculate the remaining time you want to use and instruct the stinger function accordingly (script)
#3 Posted : Thursday, February 6, 2020 12:50:16 PM(UTC)
@ dim_111
You have a couple of options:
a) You could adjust the "Mark Out" point of the video clip and use the "OnCompletion" Trigger.
b) If you know the length of the video, you could set up a timer that is just shy of that and use the "OnCountdownCompleted" Trigger.
tkachuk.alex
#4 Posted : Thursday, February 6, 2020 6:54:01 PM(UTC)
tkachuk.alex
Ukraine
Originally Posted by: IceStream Go to Quoted Post
@ dim_111
option "a" - not good. I think, because I have same problem, it's because stinger with alpha chanel, so it must start 1 second to the end, else it will be freeze picture with a stinger.
#5 Posted : Thursday, February 6, 2020 9:34:40 PM(UTC)
@ tkachk.alex
Then option "b" should work well if set-up properly.
That is, Trigger the countdown to start when the video transitions in and Trigger the Stinger to play on countdown completion.
(I might suggest giving it more than a second depending on your Stinger, but a little trial and error tweaking to get it right and it should work like a charm)
