#1 Posted : Saturday, August 6, 2011 8:57:11 AM(UTC)
Was thanked: 4788 time(s) in 1643 post(s)
*Updated*
The test release of vMix 2011 v11 is now available and includes numerous bug fixes and changes.
http://www.vmix.com.au/d...oad/vmix2011v11testb.exe
Some of the changes include:
* PlayList has been changed to save PlayList along with Preset automatically.
* PlayList items can now set a start time for each video clip.
* Fixed issue causing some video recordings to stop suddenly.
* Video recordings should now be less susceptible to dropped frames.
* Enhanced error reporting for capture devices.
* ffdshow is blocked by default as it has numerous outstanding bugs. This functionality can be changed from the Settings -> Decoders -> Blocked Filter List item.
TestB also includes the following changes:
* New Virtual GenLock code that that fixes some jitter issues with DeckLink cards under rare circumstances.
Anyone experiencing smoothness issues should try this version.
* Virtual GenLock can now be selected on a per capture basis, for cases where multiple different cards are used in different configurations.
* Additional error reporting and optimisations when using DV and HDV cameras.
Please report any bugs here.
Thanks,
melody
#2 Posted : Saturday, August 6, 2011 11:30:20 AM(UTC)
Rank: Guest
Groups: Guests
hi martin,
i`ve tested this new v11, the bug still there... second firewire source still freezed at first frame with or without ffdshow blocked.
i realy liked the "blocked filter list item" option, is very usefull.
thank you for the attention, regards,
melody
www.espiritosanto.cc
#3 Posted : Saturday, August 6, 2011 12:27:41 PM(UTC)
Does the second device work if you tick "Use VMR"?
Thanks,
melody
#4 Posted: : Saturday, August 6, 2011 1:02:33 PM(UTC)
Rank: Guest
Groups: Guests
no, it shows me an error that "one of the pins must be connected...", after that, i untick the "VMR" and it shows me an error that "device is not supported"
all error reports sended now.
note: i have tested with and without ffdshow filtering and the same problem persists.
regards,
melody
#5 Posted : Sunday, August 7, 2011 7:55:55 AM(UTC)
I have updated v11 with a new version.
See if it makes a difference, I have updated the original post with furthr details on this update.
Thanks,
melody
#6 Posted : Sunday, August 7, 2011 10:55:18 PM(UTC)
Rank: Guest
Groups: Guests
hi martin,
this new v11testb still giving me the same problem. the second firewire source doesn`t work correctly.
note that v9 don`t have this bug.
regards,
melody
#7 Posted : Monday, August 8, 2011 12:27:57 AM(UTC)
Hi Melody,
Please run the following tests:
They must be done on the same computer with the two cameras attached in the same way:
1. Try vMix 2011 v11b with VMR9 ticked
2. Try vMix 2011 v11b with Virtual GenLock unticked
3. Provide a screenshot of the filter list for the second camera under vMix 2011 v11b
4. Reinstall vMix 2011 v9b on to same computer and try two cameras again and tick the audio checkbox for each one.
Provide a screenshot of the filter list for the second camera.
These tests will be helpful in fixing the issue, but only if all the tests are run to eliminate possible issues with the computer itself.
Thanks,
melody
#8 Posted : Tuesday, August 9, 2011 6:34:13 AM(UTC)
Rank: Guest
Groups: Guests
hi martin,
here are the results to the tests:
3. http://imageshack.us/pho...xv11testbcam2filter.jpg/
4. http://imageshack.us/pho...xv9bcam2filterlistw.jpg/
notes: audio checkbox ticked
notes: audio checkbox unticked
when audio checkbox is ticked in v9 the same problem come, second source blocks at first frame, but if untick audio checkbox camera works well.
thank you martin about v11 dv and hdv improvements, now my cameras works at 1024x576 (native).
please, if you can, try to enable 1024x576 at external output device, you know the general resize problems.
regards,
melody
