lpesiney
#1 Posted : Friday, January 31, 2020 8:57:22 AM(UTC)
lpesiney
Ecuador
Scenario:
1- I Did create a new video entrance in Vmix from skype (local) and Skype (external user)
2- Opened Input Select Window.
3- I selected NDI/Video Capture option
4- Displayed all video feeds actived in the network.
5- All windows are in black.
6- After the entrance was created displayed black too in the preview window
Could somebody explain me if I did an error in the configuration or is a bug?
Thanks VMIX ERROR 01.jpg (119kb) downloaded 0 time(s). VMIX ERROR 03.jpg (211kb) downloaded 0 time(s). VMIX ERROR 02.jpg (222kb) downloaded 0 time(s).
elvis55
#2 Posted : Friday, January 31, 2020 5:19:49 PM(UTC)
elvis55
Switzerland
Matou
#3 Posted : Monday, March 9, 2020 6:45:28 PM(UTC)
Matou
Italy
Hi, I followed the tutorial step by step but unfortunately the video always remains black.
Does it just happen to me?
To understand if the problem in particular is specific to a type of PC (hard and softwhare).
Thank you all
- Asus GT752v
mavik
#4 Posted : Monday, March 9, 2020 11:48:18 PM(UTC)
mavik
One option to valiate.
Update NDI to the latest.
Make sure you use a 1GB hard wire connection.
Test in Newtek Studio monitor.
If the video is not appearing it could be very likely a network issue that the data can't be received.
Matou on 3/10/2020(UTC)
Matou
#5 Posted : Sunday, March 15, 2020 9:01:21 PM(UTC)
Matou
Italy
ciao a tutti,
prima spiego in italiano poi userò Google translate.
Il problema che non riuscivo a risolvere con Skype NDI e che apparentemente non funzionava. Seguivo passo dopo passo il tutorial ma l'immagine e l'audio non funzionavano.
Pensando e ripensando ho provato a collegarmi alle rete ADSL (normalmente uso un router con la SIM perchè è decisamente più veloce!) e improvvisamente Skype NDI cominciava a dare segni di vita. Mi sono ricordato che già anni fa si era scoperto che i gli operatori TIM e Vodafone "boicottavano" i collegamenti Voipe (tipo Skype) con le chiavette.
In pratica, per farla breve, ho riconfigurato il mio pc con i dns alternativi ( ho cancellato e fatto riconfigurare la rete ethernet partendo dai classici 1.1.1.1 e 1.0.0.1 ) e lasciando che windows trovasse il dchp da solo e configurasse i dns della chiavetta e l'ip in modo automatico.
Cos'ì funziona.
Spero che possa servire, almeno come punto di partenza.
Ciao buona giornata e come diciamo in Italia: #andràtuttobene
Hi to all,
first I explain in Italian then I will use Google translate.
The problem that I was unable to solve with Skype NDI and that apparently was not working. I followed the tutorial step by step but the image and audio did not work.
Thinking and rethinking I tried to connect to the ADSL network (normally I use a router with the SIM because it is much faster!) And suddenly Skype NDI was starting to show signs of life. I remembered that already years ago it was discovered that the operators TIM and Vodafone "boycotted" Voipe connections (like Skype) with the sticks.
In practice, to make a long story short, I reconfigured my PC with alternative DNS (I deleted and had the Ethernet network reconfigured starting from the classics 1.1.1.1 and 1.0.0.1) and letting Windows find the dchp by itself and configure the DNS of the key and IP automatically.
What works.
I hope it can serve, at least as a starting point.
Hello good day and as we say in Italy: #andràtuttobene (# will go all right)
