DDOtoo
#1 Posted : Friday, December 6, 2013 3:13:44 PM(UTC)
DDOtoo
Hello, I have been tasked to set up a portable video studio at my church, I have researched hard and I am currently left with one major hurdle, what device can best capture 3 or more cameras for use on Vmix? I have looked at Atem TV Studio and was really excited about it but upon watching the tutorial videos however I am under the impression that the output will not give me all cameras streaming independtly unto my computer for vmix to capture them independently. Please correct me if I am wrong. And if I am right then what would you suggest I use to capture multiple cameras into Vmix?
Thank you.
r@wisla
#2 Posted : Friday, December 6, 2013 5:44:18 PM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
You're right.
Atem TV Studio is not a capture device. It's hardware switcher. vMix is software switcher.
There are several multichannel capture cards made by Osprey, Blackmagic Design, Magewell, Yuan...
thanks 1 user thanked r@wisla for this useful post.
DDOtoo on 12/6/2013(UTC)
DDOtoo
#3 Posted : Friday, December 6, 2013 7:26:46 PM(UTC)
DDOtoo
r@wisla wrote:
You're right.
Thank you for that, if you don't mind me asking could you suggest one preferable one that can capture at least 4 cameras at a time?
One again thank you kindly
Damn2Good4U
#4 Posted : Friday, December 6, 2013 8:41:58 PM(UTC)
Damn2Good4U
DDOtoo wrote:
r@wisla wrote:
You're right.
Magewell card XI204XE will capture 6 cameras - 2 HDs and 4 SDs
See it here http://www.magewell.com/...xe_features.html?lang=en
I have one and it works perfectly with vMix
thanks 1 user thanked Damn2Good4U for this useful post.
Troviss
#5 Posted : Sunday, December 8, 2013 6:22:01 PM(UTC)
Troviss
I have tested vmix and uses 4 USB cameras simultaneously without problems. I'm surprised that you can run as many cameras and blend between them , without any problems at all. CPU is very low so it is safe to run more if you want .
I bought a USB 7 port hub for a few dollars , which has signal amplification , so I can run with long usb cables. With proper signal amplifier so you can drive with cables that are 328 feet long , but you need the certainly not over 65 - 98 feet in a church.
I'll also build a portable studio for the church and then uses usb mini camera 808 # 16 ( Eletoponline365 is top -rated sellers )
I bought this cameras:
808 #16
I bought 4 pan and tilt platforms of this:
pan and tilt
I control all cameras with small servos for pan and tilt from a controller table from the computer
All 8 servos controlled with 8 servo tester from HobbyKing.
http://www.hobbyking.com...item.asp?idproduct=42010
I bought 5 x 2 = 10 cords of these :
http://www.hobbyking.com...item.asp?idproduct=43753
The cables should be spliced ​​with another cheap 3 conductor cable to the correct length .
You need power to run everything and I do not want to fuss with batteries to be recharged, but I will drive all the servos and servo controllers with a single device. I have calculated that all need approx . 6 volts and 50 amps of power to operate. This should be enough to power everything :
Power for all.
There is of course much better cameras than 808 # 16, but the fact is that these provide equally good picture when I I plug in a Panasonic HD DV camera via firewire . Mobius action cam is the better , but also more expensive. I think it might be good to build up a cheap option at the beginning to try and learn to mix nicely in the recordings and then will do 808 # 16 well .
If you want a really good cameras so there are these :
http://www.jai.com/en/ne...-ccd-cameras-vision-2012
But before you buy usb3 cameras, be shure it is possible to use them in vMix. Good luck with the studio.
thanks 1 user thanked Troviss for this useful post.
DDOtoo on 12/8/2013(UTC)
HWL1223
#6 Posted : Sunday, December 8, 2013 6:28:28 PM(UTC)
HWL1223
does anyone in the US sell Magewell?
r@wisla
#7 Posted : Tuesday, December 10, 2013 4:14:51 PM(UTC)
r@wisla
HWL1223 on 12/10/2013(UTC)
