Feature Requests
IRP Select event by Number
it would be great to select an event by number with shortcuts
at the moment we only have ReplaySelectFirstEvent ReplaySelectLastEvent ReplaySelectNextEvent ReplaySelectPreviousEvent
to Select Event 20 off 100 you have to send 21 messages to vMix to select the correct one Why is there no Shortcut for ReplaySelectEventNumber
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: xaver  it would be great to select an event by number with shortcuts
to Select Event 20 off 100 you have to send 21 messages to vMix to select the correct one Why is there no Shortcut for ReplaySelectEventNumber Have you checked ReplayPlayEvent and give it a number ?
I use IRP as MAZ with a complete control by a second PC
I only want to select it, to see if it's the correct one. Then I select different events in different angles and play them automaticly
If I use ReplayPlayEvent it immediately play's it ( and that's not useable in our workflow )
Got ya but in the mean time you could shortcut ReplayPlayEventById and let the same shortcut call a script to stop the replay needs to be in a script in order to add a small delay as its responding to fast otherwise Code:sleep(100)
API.Function("ReplayStopEvents")
could put ReplayPlayEventById in the script too Just a thought
I tried it, but the "screen" becomes very "nervous"
If I select an event, the first frame comes on the screen
If I do it with playeventbyid and pause or stop, I need a litle break (as you write about 100-200msec) and in this time, I get moving pictures
I fear that our volunteers will not be able to cope with it
So I decide to do it with the work around (select first and then select next Or select last and then select previous)
Still waiting for a new shortcut "ReplaySelectEventByID"
Feature Requests
