xaver
#1 Posted : Saturday, January 25, 2020 10:19:46 PM(UTC)
xaver
it would be great to select an event by number with shortcuts
at the moment we only have
ReplaySelectFirstEvent
ReplaySelectLastEvent
ReplaySelectNextEvent
ReplaySelectPreviousEvent
to Select Event 20 off 100 you have to send 21 messages to vMix to select the correct one
Why is there no Shortcut for ReplaySelectEventNumber
#2 Posted : Saturday, January 25, 2020 10:38:41 PM(UTC)
Have you checked ReplayPlayEvent and give it a number ?
xaver
#3 Posted : Saturday, January 25, 2020 11:33:56 PM(UTC)
xaver
I use IRP as MAZ with a complete control by a second PC
I only want to select it, to see if it's the correct one.
Then I select different events in different angles and play them automaticly
If I use ReplayPlayEvent it immediately play's it ( and that's not useable in our workflow )
#4 Posted : Sunday, January 26, 2020 12:44:26 AM(UTC)
Got ya
but in the mean time you could shortcut ReplayPlayEventById and let the same shortcut call a script to stop the replay
needs to be in a script in order to add a small delay as its responding to fast otherwise
Code:
sleep(100)
API.Function("ReplayStopEvents")
could put ReplayPlayEventById in the script too
Just a thought
xaver
#5 Posted : Sunday, January 26, 2020 4:37:11 AM(UTC)
xaver
I tried it, but the "screen" becomes very "nervous"
If I select an event, the first frame comes on the screen
If I do it with playeventbyid and pause or stop, I need a litle break (as you write about 100-200msec) and in this time, I get moving pictures
I fear that our volunteers will not be able to cope with it
So I decide to do it with the work around (select first and then select next Or select last and then select previous)
Still waiting for a new shortcut "ReplaySelectEventByID"
