matteoarrigone
#1 Posted : Friday, January 24, 2020 11:27:02 PM(UTC)
matteoarrigone
I've updated to version 23.0.0.38 and I would like to try to use the new function about Mix and triggers but when I create a trigger on input there isn't the option for Mix 4.
For example, I would like to 'active input 1' on Mix 4 on 'input 5 Overlay in' but there isn't the option for mix 4.
Is this a bug?
Matteo
#2 Posted : Saturday, January 25, 2020 1:37:55 AM(UTC)
Apologies, I misunderstood your question.
I can confirm it isn't showing the fourth Mix which is quite odd since it uses the same box
as in the shortcuts window, but we'll get it fixed in the next update.
matteoarrigone on 1/25/2020(UTC)
