vMix 23.0.0.38 support for selecting Mix when using triggers
Joined: 2/18/2018(UTC) Posts: 28  Location: Milan, Italy Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
I've updated to version 23.0.0.38 and I would like to try to use the new function about Mix and triggers but when I create a trigger on input there isn't the option for Mix 4. For example, I would like to 'active input 1' on Mix 4 on 'input 5 Overlay in' but there isn't the option for mix 4. Is this a bug?
Matteo
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Apologies, I misunderstood your question. I can confirm it isn't showing the fourth Mix which is quite odd since it uses the same box as in the shortcuts window, but we'll get it fixed in the next update.
