davidcallahan
#1 Posted : 5 years ago
davidcallahan
I'm desperatly trying to create titles (with background) where the background has the same width as the text's layer width.
Is it possible to make that in UTC ? I might be wrong but it can't be done in GT right ?
Thanks a lot.
David
#2 Posted : 5 years ago
Was thanked: 989 time(s) in 821 post(s)
Thanks a lot.
David
if only there was google or this forum had a search ;-) ?
davidcallahan on 1/23/2020(UTC)
davidcallahan
#3 Posted : 5 years ago
davidcallahan
Thanks a lot !
I've been using the wrong keyword for my searches... Never used "auto sizing", but "dynamic" instead. Which returns nothing
That's great thanks, but is there a way to manage those boxes' size without text in it ? For statistics for instance.
Thanks again
#4 Posted : 5 years ago
Thanks again
Like a bar graph ?
spaces are not visible in a textblock , so the more of them the longer the colored bar bounded to the textbox becomes
davidcallahan
#5 Posted : 5 years ago
davidcallahan
Exactly, a bar graph.
That was my idea to use spacing, but it seems a bit DIY :D
#6 Posted : 5 years ago
whatever works ;-) and vMix is a to be creative DIY tool lol
For more fancy graphic options there is alots of none DIY software around but at a cost
davidcallahan
#7 Posted : 5 years ago
davidcallahan
Do you have some software names to help out please ?
If I want to work on it on my own, like scripting/developing, do you know where I can find APIs ?
Thanks again
#8 Posted : 5 years ago
Thanks again
vMix allows you to a lot in this sense .
For one you have the legacy XAML titles where you can put a lot of code behind it .
Now with Gt titles one can do a lot if you animations combined it with vMix scripting .
There is a developers section in the vMix helpfiles about API calls etc not to mention the use of data sources in vMix
mix it all together and a bit of fantasy and you can create quit a bit of interesting stuff.
There are video tutorials and quite a bit to find back in this forum also
davidcallahan
#9 Posted : 5 years ago
davidcallahan
Thanks a lot, I'll dig into that !
#10 Posted : 5 years ago
Thanks again
BTW from an older post (XAML though)
a bar graph example
