Joined: 1/22/2020(UTC) Posts: 47  Location: Montpellier Thanks: 14 times Was thanked: 2 time(s) in 2 post(s)
Hi, I'm desperatly trying to create titles (with background) where the background has the same width as the text's layer width. Is it possible to make that in UTC ? I might be wrong but it can't be done in GT right ?
Thanks a lot.
David
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: davidcallahan  Hi, I'm desperatly trying to create titles (with background) where the background has the same width as the text's layer width. Is it possible to make that in UTC ? I might be wrong but it can't be done in GT right ?
Thanks a lot.
David if only there was google or this forum had a search ;-) ?
Thanks a lot ! I've been using the wrong keyword for my searches... Never used "auto sizing", but "dynamic" instead. Which returns nothing That's great thanks, but is there a way to manage those boxes' size without text in it ? For statistics for instance.
Thanks again
Originally Posted by: davidcallahan  is there a way to manage those boxes' size without text in it ? For statistics for instance.
Thanks again Like a bar graph ? spaces are not visible in a textblock , so the more of them the longer the colored bar bounded to the textbox becomes
Exactly, a bar graph. That was my idea to use spacing, but it seems a bit DIY :D
Originally Posted by: davidcallahan  That was my idea to use spacing, but it seems a bit DIY :D whatever works ;-) and vMix is a to be creative DIY tool lol For more fancy graphic options there is alots of none DIY software around but at a cost
Do you have some software names to help out please ? If I want to work on it on my own, like scripting/developing, do you know where I can find APIs ? Thanks again
Originally Posted by: davidcallahan  If I want to work on it on my own, like scripting/developing, do you know where I can find APIs ?
Thanks again
vMix allows you to a lot in this sense . For one you have the legacy XAML titles where you can put a lot of code behind it . Now with Gt titles one can do a lot if you animations combined it with vMix scripting . There is a developers section in the vMix helpfiles about API calls etc not to mention the use of data sources in vMix mix it all together and a bit of fantasy and you can create quit a bit of interesting stuff. There are video tutorials and quite a bit to find back in this forum also
Thanks a lot, I'll dig into that !
Thanks again BTW from an older post (XAML though) a bar graph example
