hanan.sharivkin
#1 Posted : Monday, January 20, 2020 7:14:23 PM(UTC)
hanan.sharivkin
Hi.
i'm sending commands to VMIX to remotely start s script:
http://127.0.0.1:8088/api/?Function=ScriptStart&Value="myscript"
is there a way i could send a parameter and use t within Http Request Call ?
i know there is something called "ScriptStartDynamic" but couldn't find any useful documentation or examples...
Thank you.
#2 Posted : Monday, January 20, 2020 8:39:48 PM(UTC)
https://forums.vmix.com/...Dynamic-Script#post26214
hanan.sharivkin
#3 Posted : Monday, January 20, 2020 9:47:41 PM(UTC)
hanan.sharivkin
can ScriptStartDynamic be used for a simple Parameter add to a script start?
#4 Posted : Monday, January 20, 2020 10:22:42 PM(UTC)
Don't believe so but if dynamic is the same as creating a script on the fly you could add it there
WOuld be interesting to know what sort of parameter one is talking about as there are potential workarounds to it like using a title's textbox to hold the parameter , even fed by a datasource, that the script can then read
You have to specify your parameter somehow ;-)
hanan.sharivkin
#5 Posted : Tuesday, January 21, 2020 12:39:43 AM(UTC)
hanan.sharivkin
Hi Sure :)
here is what we need:
Starting a script to Go to Commercials with the Duration of the break as parameter...
Or Start playing a clip with the clip name, and a tittle with the Artist Name and Album as Parameter
#6 Posted : Tuesday, January 21, 2020 4:22:20 AM(UTC)
Hi Sure :)
I would think all this data is know ahead of time somehow not ?
So why not look into using Data Sources to have your schedule and lists and use scripts to retrieve that to make the appropriate functions
Data Source are usually linked to titles , so you can use a (hidden) title as a placeholder for the data for the script to read
Check out the vMix videos about using datasources in vMix
