kgoodyer
#1 Posted : Wednesday, June 29, 2016 4:58:11 AM(UTC)
kgoodyer
Was thanked: 53 time(s) in 27 post(s)
Apart form hitting the API externally, or starting a script from withing the script editing console, how do you run a script? I presumed I could add it to a trigger, and the option to 'Start Script' is there - but there seems no way to specify which script is executed.
Also what is a Dynamic Script? I can't find anything about it in the documentation or in these forums.
Cheers
Keith
#2 Posted : Wednesday, June 29, 2016 5:04:09 AM(UTC)
Was thanked: 4801 time(s) in 1648 post(s)
Scripts can be started from shortcut keys, called from the API and now in vMix 17 called from triggers as well.
StartScriptDynamic is described in the help file under Shortcut reference and is a way to
start a script without having to create a script in vMix first, the value can be the code itself.
http://www.vmix.com/help...utFunctionReference.html
kgoodyer
#3 Posted : Wednesday, June 29, 2016 5:06:05 AM(UTC)
kgoodyer
Thanks, just realised I was working on a VMIX V16 box, just seen how it all works in V17 - thanks
