Skype/OOVOO calls and display of website as PiP
Hello good people of vMix Community
How do I please:
1. Bring in an entire website into vMix assuming I want to show it as a whole or as PiP?
2. Bring in Skype Callers 1 or 2 at the same time into vMix
3. Oovoo or Google Hangout callers in...
Need your help to boost my production...
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
My first and easiest thought is to have elements you want on a secondary attached monitor then running the screen capture utility locally grab the number two monitor. This monitor will need to be high enough resolutions for all to look good. with elements separate and sized to maximized quality create virtual copies of the original captured module then crop, position and zoom to fit. These can be assembled in multiple ways depending on your needs. Good luck
 1 user thanked Egriswold for this useful post.
