Selecting Mix with Triggers
Joined: 10/20/2016(UTC) Posts: 57 Location: Virginia-USA
Thanks: 5 times Was thanked: 6 time(s) in 4 post(s)
I'm playing with the mini-mixers and while I figured out how to specify the mix via web api and hotkeys, I haven't been able to get triggers to specify a mix. Is it possible and I just missed it? Or is something missing?
What I'm trying to accomplish is when an Input is active/live, the trigger would also transition Mix2 to a specified input.
Thanks Jon
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
There seems to be no way to do this in the Triggers window. But setup shortcut to do the mix change and trigger KeyPress function.
Thanks, kind of thought so, wonder if I can script it.
Jon
