	Selecting Mix with Triggers
 Thanks: 5 timesWas thanked: 6 time(s) in 4 post(s)
                I'm playing with the mini-mixers and while I figured out how to specify the mix via web api and hotkeys, I haven't been able to get triggers to specify a mix. Is it possible and I just missed it? Or is something missing?
 What I'm trying to accomplish is when an Input is active/live, the trigger would also transition Mix2 to a specified input.
 Jon
 Joined: 2/23/2017(UTC) Posts: 189 Thanks: 1 timesWas thanked: 52 time(s) in 42 post(s)
                There seems to be no way to do this in the Triggers window. But setup shortcut to do the mix change and trigger KeyPress function. |
                Thanks, kind of thought so, wonder if I can script it.
 Jon
