Systems
New vMix system / how many PCI cards ? Ryzen ?
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi all,
I'm planning on building a second vMix system, the first is an Omen driven laptop and I have to say works like a charm. But the use of thunderbolt connector between the laptop and the cards is a potential risk with a small unsecured plug... I'd rather have a desktop vMix solution to bring on bigger gigs.
So here we are : I've seen a lot of Z390 motherboards which have 2 or 3 PCI slots, how could you fit 3 or 4 deckling cards ? (plus the GPU)
If I need a 10G ethernet I'll probably have to go for a network card which will fit another slot.
And I've heard Ryzen CPUs are faster (especially with multithreading) and cheaper. But do they work well with vMix ?
I'll probably have a couple of other questions later, but let's start with that ;)
Thanks all and have a great Xmas time !
you have to check how many lanes are on the PCI Bus each decklink needs their own lanes also the GPU (I'm not sure at the moment how many for the Decklink and for the GPU)
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
@ ukcpw I would look the the new X299X chipset based motherboards coming out Take a look at the Gigabyte X299X DESIGNARE 10G as an option Gigabyte X299X DESIGNARE 10GHas dual 10G Ethernet ports built in.
Thank you all I’ll take a minute to check that out after Xmas time. Have a nice one !
Systems
