hakan_forss
#1 Posted : Thursday, December 26, 2019 2:21:35 AM(UTC)
hakan_forss
Sweden
It would be awesome if you could do multiple function calls per shortcut without duplicating the whole shortcut. This would replace the current Advanced tab that only sends new key stokes.
#2 Posted : Thursday, December 26, 2019 2:43:07 AM(UTC)
Does putting (clone and edit) them all under the same key not work for you ?
See help files : Assigning Multiple Functions to a single Shortcut
hakan_forss
#3 Posted : Thursday, December 26, 2019 3:04:39 AM(UTC)
hakan_forss
Sweden
That will be very error prone and take a lot of extra effort
#4 Posted : Thursday, December 26, 2019 3:09:08 AM(UTC)
The please explain how you envision your request as i have a hard time visualizing it
hakan_forss
#5 Posted : Thursday, March 5, 2020 7:28:25 AM(UTC)
hakan_forss
Sweden
What I envision is very similar to how you add triggers. You can add multiple triggers in a list. In this case you would add multiple function calls for each hot key
raugert
#6 Posted : Thursday, March 5, 2020 2:11:58 PM(UTC)
raugert
Canada
Was thanked: 322 time(s) in 184 post(s)
You can use a script to execute multiple commands If you need help to build the script you can use the vMix Script Builder app.
https://forums.vmix.com/...r-App---Updated-02-24-20
