Feature Requests
Multiple function calls per shortcut
It would be awesome if you could do multiple function calls per shortcut without duplicating the whole shortcut. This would replace the current Advanced tab that only sends new key stokes.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Does putting (clone and edit) them all under the same key not work for you ?
See help files : Assigning Multiple Functions to a single Shortcut
That will be very error prone and take a lot of extra effort
Quote:take a lot of extra effort The please explain how you envision your request as i have a hard time visualizing it
What I envision is very similar to how you add triggers. You can add multiple triggers in a list. In this case you would add multiple function calls for each hot key
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
Feature Requests
