vMix Call
Chrome No Longer Sees External Video
Thanks: 3 times Was thanked: 6 time(s) in 6 post(s)
Many times I will use vMix Call to connect to a studio just to simply listen in and watch the video of a live production while I produce notes for a production. And most of the time I don't even have a webcam connected to my computer. Usually this is no problem since I also have vMix installed on my PC and Chrome sees "vMix Video External 2" as the camera with color bars, allowing for vMix Call to successfully make a connection.
However beginning with Chrome version 78, and now 79, this no longer works. Chrome no longer see "vMix Video External 2" as a working camera, and thus does not successfully connect.
If I uninstall Chrome, then install Chrome 76, this all works again.
Any idea what's going on and how to fix this so I don't have to plug a webcam in?
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 319 times Was thanked: 263 time(s) in 233 post(s)
Appears to be working fine for me. Latest release of vMix and Chrome, using 8x8 free video conference tool, which is webrtc based.
Thanks: 86 times Was thanked: 7 time(s) in 7 post(s)
vMix admin posted an update a few days ago and mentioned the following notes; I wonder if it applies to your situation? If yes, maybe try to update your version of vMix to the latest version?
23.0.0.32
* Added workaround for Google Chrome update causing vMix Video device to no longer work. * Fixed FMLE no longer working as the streaming application. * Updated vMix Desktop Capture to 23.0.0.2 with fix for old CPUs without AVX support.
Originally Posted by: mgrayeb  vMix admin posted an update a few days ago and mentioned the following notes; I wonder if it applies to your situation? If yes, maybe try to update your version of vMix to the latest version?
23.0.0.32
* Added workaround for Google Chrome update causing vMix Video device to no longer work. * Fixed FMLE no longer working as the streaming application. * Updated vMix Desktop Capture to 23.0.0.2 with fix for old CPUs without AVX support. I've only got vMix 22 on my PC.
Thanks: 18 times Was thanked: 2 time(s) in 2 post(s)
23.0.0.32
* Added workaround for Google Chrome update causing vMix Video device to no longer work. * Fixed FMLE no longer working as the streaming application. * Updated vMix Desktop Capture to 23.0.0.2 with fix for old CPUs without AVX support. Originally Posted by: sunkast  I've only got vMix 22 on my PC. Oh shucks, just found this thread. Been trying to figure this out since last Friday (12/13), Chrome will not connect to vMix Video device anymore (worked 12/12 and before). We are on 21.0.0.61. For now, I had switched to Firefox for the time being. Do want Chrome to work. Cleared all cache/history, reset permissions, even uninstalled / reinstalled Chrome. No go. I wonder if it has to do with that Chrome 79 bug. Has the admin posted specifics? .
I've resorted to just using the NewTek virtual cam to feed a blank screen to Chrome.
Joined: 10/13/2012(UTC) Posts: 1,162  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
Working fine for me on Chrome Version 79.0.3945.88 (Official Build) (64-bit)
Joined: 3/7/2012(UTC) Posts: 2,661  Location: Canada Thanks: 33 times Was thanked: 509 time(s) in 478 post(s)
vMix Call
