@ e.belyshev
vMix HD (and below) has always only supported 1x Fullscreen Output and 1x External Output. Only vMix 4K and vMix Pro support a 2nd Fullscreen Output and a 2nd External Output. Perhaps you were using the free 60 Day Trial (which is equivalent to vMix Pro).
Ice Nevermind then. I use 1 NDI out & 1 Blackmagic out & to me that's two external outputs.
Perhaps not a bug, but when Setting things up that asks for a restart (e.g. changing an Audio Output) vMix's windows sizes and postions are not remembered after the restart (including pop-out audio mixer, list, etc). Same thing happens in v22.
Joined: 11/13/2019(UTC) Posts: 4  Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: dabex  Hi, how can i ingest 8 audio channels with SRT? I receive a stream with 8 audio ch but I only see two of them.
Many thanks! Anyone who can answer my questions? Thanks a lota!
Originally Posted by: raugert  @stevespaw The API commands for "Mix" inputs: http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Mix=0 (vMIx Main) http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Mix=1 (Mix 2) http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Mix=2 (Mix 3) http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Mix=3 (Mix 4) The Mix index in the API starts at "0" which is a little different than in the shortcut settings (Mix1-4). Richard Just played with this, and it appears to work, however, I'm unable to select the mix input by GUID. @admin aAm I doing this wrong, or can it be added? Attempting to use either of the URLs below changes the vMix Man Output rather then my intended mix input. http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Mix=dccd67f1-0d0e-4e2c-a17d-bdc8a6d000d6 http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Input=1&Mix=dccd67f1-0d0e-4e2c-a17d-bdc8a6d000d6
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
I think your syntax is wrong. The GUID should be the GUID of the Input that you want to fade to. The mix value selects the Mix input that you want to control. (value 0-3) Try: http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Input=dccd67f1-0d0e-4e2c-a17d-bdc8a6d000d61&Mix=1
 2 users thanked raugert for this useful post.
Originally Posted by: raugert  I think your syntax is wrong. The GUID should be the GUID of the Input that you want to fade to. The mix value selects the Mix input that you want to control. (value 0-3) Try: http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Input=dccd67f1-0d0e-4e2c-a17d-bdc8a6d000d61&Mix=1 You're correct based on the wording I had, I just phrased question wrong. We've been able to select ?input= by GUID, but I'm not able to do the same with ?mix=. My concern is that if the input is dragged before/after another mix input, that the affected mix input won't be controlled. I'd rather send a GUID than relative mix id. Something like this would've been better for me to post: http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Input=86f8b905-e73e-462e-b888-2a68061351b7&Mix=dccd67f1-0d0e-4e2c-a17d-bdc8a6d000d61
Ah OK, I think you might be using the command the wrong way. I'll try my best to explain: When controlling a "Mix" Input, you normally don't include the Input name or GUID in the command string. You simply send the desired transition command (cut, fade etc) to the Mix Input (2,3,4) you wish to control. The values for "Mix" are used to select the desired Mix Input you wish to control and not the Input you want to switch to. Value 0 will control the vMix Main Mix Value 1 will control the Mix2 Input Value 2 will control the Mix3 Input Value 3 will control the Mix4 Input Example: http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Mix=1 (The current Preview Input which is selected in the "Mix2 Input" will then Fade to the Output you have selected in the "Mix2 Input") If you do choose to include an "Input" in the command string it will transition directly to that Input within the "Mix Input". Example: http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Input=86f8b905-e73e-462e-b888-2a68061351b7&Mix=1 (The Input you have indicated will then Fade directly to the Output you have selected in the "Mix2 Input" ) It's a little bit confusing at first but I hope that helps. cheers, Richard
 1 user thanked raugert for this useful post.
Hi, the 8 audio buses are really great!! This is absolutely a killer-feature for me. Could be very very useful to be able to assign busses DEFG to an output other than MABC and MABCDEFG.
When you have 8 ch in input and 8 different ch in output (as i'm testing for an actual production) this could be necessary.
Thank you very much!
You have been a member since:: 1/13/2010(UTC) Posts: 5,337  Location: Gold Coast, Australia Was thanked: 4740 time(s) in 1626 post(s)
23.0.0.27http://cdn.vmix.com/download/vmix23preview.exe* Added new GT Text and GT Timer built in templates * Improved Facebook API support, now allows selecting existing scheduled streams to stream to and also to allow creating new scheduled stream directly from vMix. * Added reset right click menu for SRT input * Tally lights will now indicate correctly if Mix input is in Output * Check box for local access added to Web Controller settings to allow local apps to connect without password. * Activators added for Mix input (InputMixX and InputPreviewMixX) * Mix input status added to API XML * Fixed issue where offline replay input would stop shortcuts from working. * Fixed some issues where auto shrink GT titles may shrink more than necessary. * Fixed issues when using Intel Hardware HEVC encoder for SRT streams. * Fixed issues with Replay "Use Source Settings" for colour correction., * Fixed SRT stats not displaying correctly since 1.4 update.
 7 users thanked admin for this useful post.
Thanks: 86 times Was thanked: 7 time(s) in 7 post(s)
Love the new GT Text templates! Can already see how much sharper it looks side by side with the old XAML style. Really like the drop shadow template! Thank you very much!
Joined: 10/1/2013(UTC) Posts: 196  Location: Bovalino (Italy) Thanks: 86 times Was thanked: 3 time(s) in 3 post(s)
I hope to make a video tutorial for an SRT connection
Joined: 8/3/2013(UTC) Posts: 48  Location: Florida Thanks: 19 times Was thanked: 1 time(s) in 1 post(s)
 pop warner.gtzip (197kb) downloaded 8 time(s).Perhaps a small bug related to GT title designer. when trying to create a text box so that the text moves from right to left I cannot seem to get it to work under these conditions. When automatic text box resizing is set to "width and height" my textbox seems to lose the right to left functionality. I am trying to build a scoreboard and have the home team name expand out from the center of the screen to the right the way default text responds but when I create the visitor text box and try to get it to expand from the center of the screen to the left it does not work whenj "width and height" gets checked. I would like to have both of these text boxes resize automatically as different length team names are retreived from data sources and they are also backed by bound rectangles which also follow the length of the text box. When other text box size options are chosen such as "fixed" "width" and "height the right to left seems to work ok. its only when set to "width and height" is chosen. I see this same issue was posted on post #12 on this topic but as of the latest beta release it is still not working and in some other posts I see where Admin states that in the case of "width and height" being selected that the text box will always be anchored in the top left however if you look at the scoreboard file I have attached I am not sure how to get the text behavior I have described where there is a home and away text box which both expand out from the center of the screen
As already noted, as it is anchored to the top left, if you want it to expand out from the center or right, you will need a fixed size text box the text can move/expand inside of.
Martin vMix
Joined: 11/20/2019(UTC) Posts: 2  Location: buenos aires
Joined: 8/31/2015(UTC) Posts: 31   Location: Romania Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
Originally Posted by: imagebotique   pop warner.gtzip (197kb) downloaded 8 time(s).Perhaps a small bug related to GT title designer. when trying to create a text box so that the text moves from right to left I cannot seem to get it to work under these conditions. When automatic text box resizing is set to "width and height" my textbox seems to lose the right to left functionality. I am trying to build a scoreboard and have the home team name expand out from the center of the screen to the right the way default text responds but when I create the visitor text box and try to get it to expand from the center of the screen to the left it does not work whenj "width and height" gets checked. I would like to have both of these text boxes resize automatically as different length team names are retreived from data sources and they are also backed by bound rectangles which also follow the length of the text box. When other text box size options are chosen such as "fixed" "width" and "height the right to left seems to work ok. its only when set to "width and height" is chosen. I see this same issue was posted on post #12 on this topic but as of the latest beta release it is still not working and in some other posts I see where Admin states that in the case of "width and height" being selected that the text box will always be anchored in the top left however if you look at the scoreboard file I have attached I am not sure how to get the text behavior I have described where there is a home and away text box which both expand out from the center of the screen Yeah, you need to move your graphics to Left to Right, instead of right to left, if you want that function work. Like that i did and me. Originally Posted by: admin  Hi,
Martin vMix Maybe you can try to move that anchor to top right for this type of text or/and graphics when "width and height" use right text align and isolate it.
23.0.0.28http://cdn.vmix.com/download/vmix23preview.exe* Added SetBusCVolume to SetBusGVolume shortcuts * Audio buses will now be created even if selected device is not working or is disabled. * Error message now displayed when creating a stream on a Page with privacy other than Public, as all streams on Pages are always public as per FB policy. * Two "spinner" animated GT templates added * Fixed issue with colour bars on stream when switching between presets with different stream resolutions. * Fixed error with some ASIO devices.
 6 users thanked admin for this useful post.
Joined: 12/14/2018(UTC) Posts: 163   Location: Clermont-Ferrand Thanks: 38 times Was thanked: 10 time(s) in 9 post(s)
Hello Martin,
I will have 2 questions, please.
Is it possible to install version vMix 23 beta (for testing) at the same time as version 22 on the same Windows?
Do you have an aproximative date of the release of vMix 23?
Thank you for your work.
Michael.
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 593 times Was thanked: 204 time(s) in 170 post(s)
Originally Posted by: MickeyMJJ  Is it possible to install version vMix 23 beta (for testing) at the same time as version 22 on the same Windows? Yes, you can install version 23 right over version 22. If you don't like it, just reinstalled version 22 right over v23. All of your settings, presets, etc. will be there. Originally Posted by: MickeyMJJ  Do you have an aproximative date of the release of vMix 23? vMix 23 is being released today. Check https://www.vmix.com/software/download.aspx to see when version 23 is available for download.
